Separate thread for PlaneFinding PlaceOnPlane HoloToolKit
Can someone explain how to use ThreadPool.QueueUserWorkitem or how to call PlaneFinding on a separate thread not in Update
    // Now call FindPlanes().  NOTE: In a real application, this MUST be executed on a
    // background thread (i.e.: via ThreadPool.QueueUserWorkItem) so that it doesn't stall the
    // rendering thread while running plane finding.  Maintaining a solid 60fps is crucial
    // to a good user experience.
    planes = (VisualizeSubPlanes) ?
    In our Spatial Mapping course, we use a combination of Task.Run and Unity's Coroutine to run PlaneFinding in the background. Here is the code snippet from SurfaceMeshesToPlanes that calls it:
    #if !UNITY_EDITOR
    // When not in the unity editor we can use a cool background task to help manage FindPlanes().
    Task<BoundedPlane[]> planeTask = Task.Run(() => PlaneFinding.FindPlanes(meshData, snapToGravityThreshold, MinArea));
    while (planeTask.IsCompleted == false)
        yield return null;
    BoundedPlane[] planes = planeTask.Result;
    #else
    // In the unity editor, the task class isn't available, but perf is usually good, so we'll just wait for FindPlanes to complete.
    BoundedPlane[] planes = PlaneFinding.FindPlanes(meshData, snapToGravityThreshold, MinArea);
    #endif
    is that the same as
    or are there other recommended ways to do multithread
    #if !UNITY_EDITOR
        yield return null;
    #else
    #endif
