Windows Store Menu Icon Blank, Along with Application
Hello,
After some use on my home network, the windows store button has gone blank on the menu. Clicking on the now-blank icon results in a blank application.
In device portal, I am also unable to start any applications, the list is blank.
Any hard restarts on the device do not change anything. Has anyone else encountered this?
Jabu
OptionsJabuJabu ✭
UPDATE: I am not sure what caused this to happen. A complete factory reset fixed the problem.
@JabuJabu does it work if you connect it to a different network?
Are there any pending updates in the Settings -> Update?
I updated my hardware and the 'empty button' now moved and is still not functional.
I don't see this problem anywhere else on the forums?
Same Problem here, the store button is empty and the store is not working...
