101e speech input not working
How to verify if speech input is working or not (using emulator) I tried a lot with inbuilt computer mouse bit itws not working
-1
@Jaldeep,
Do you have a microphone attached to your PC? You should be able to speak into a microphone to use the 'Reset World' and 'Drop Sphere' commands in the emulator. Also, 'Drop Sphere' won't work unless the cursor is hovering over one of the spheres.
Yes, I have a microphone attached. Also, I speak when the cursor is hovering over. still its not working
@Jaldeep Did you enable Microphone capability in Unity publishing settings for Windows Store?
Thanks @ContextVR nope. let me try doing that ? do we need to add gesture capability too ?
@Jaldeep Yes if you're using any gestures.
See my latest tutorial on using speech based input for the Hololens: https://codeholo.com/2017/12/03/using-voice-based-interactions-on-the-hololens-via-speech-input-source-speech-input-handler/ using 2017 editions of Unity and the MR Toolkit
