Apps Won't Deploy to Hololens! Please Help!
My app works completely fine with the emulator. I am able to build it to visual studio without a problem. But when I try to deploy to my Hololens, it just won't work. It says the app needs to be deployed directly. No matter what I do the deploying fails.
Hmm have you figured it out yet? What method are you using to deploy? The first thing to do is use the portal to the device in your web browser and make sure it connects to the network correctly. Next, make sure the developer mode is enabled in settings.
The usb connection method might work better for you depending on your network configuration. See https://developer.microsoft.com/en-us/windows/holographic/using_the_windows_device_portal. Be sure to get the pairing code from the device as well. Plug the device in and make sure it is on. In Visual Studio set to release x86 and device from the dropdown. Then Ctrl + F5. It worked for me.
Moving this to Q and A category
Make sure to deploy to "Device" if you are connected VIA USB. Not doing this gave me some issues early on.
I have had problem when I used third party products that uses dll's, after removing these deployment happened again.
creative mind, free thinker, dreamer, maker, mostly working on games and doodling around with gadgets, Sphered Cazual/Elite/Master of the Universe/Dad/Husband @mariovermeulen
I would think that this would be by design, I am not sure you should be able to deploy to a device that is in sleep mode.
