Programming HoloLens: Device Portal API reference for HoloLens
Jimbohalo10
This is probably better to make a new thread for articles found about programming HoloLens.
Announced on 14th April 2016
Quote:-
Everything in the Windows Device Portal is built on top of REST API's that you can use to access the data and control your device programmatically.
These are the codes that describe how the HoloLens Portal web browser works.
Follow this tutorial to get started with ASP.NET Web API and REST API
Getting Started with ASP.NET Web API 2 in C#
OptionsJimbohalo10 ✭✭✭
This article is about HoloLens Perception Simulation
Quote:-
Perception Simulation bypasses the live sensors on the HoloLens and sends simulated input to applications running on the device5
Perception simulation
very nice
Does anyone know of a way to download a copy of the Surface Reconstruction (.obj) via the 3D tab using the API?
