Can't get cursor to work in Holograms 101E
spt ✭✭
You haven't given us much to go on, but here is my suggestion:
Uninstall everything. Everything. And start over. Then, when you do start over, make sure you double-check each step of the instructions, do not just scan them, and skip NOTHING.I was getting strange results the first time I installed, and after redoing it and paying closer attention, its started working.
As it turns out, when I unzipped the sample project's folder and opened it inside of unity I opened the outermost Origami folder instead of the innermost one.
Thanks for the help!
