Am I creating a WorldAnchor position correctly?
I am exploring using Spatial Anchors known in Unity as WorldAnchors. I use the HoloToolKit to develop code using the HoloLens Emulator. Perhaps I am doing something fundamentally wrong but I want to store some WorldAnchor positions so that I could successfully load them in later using WorldAnchorStore. My relevant code snippet looks like this:-
    static public GameObject create_sphere()
        var m = GameObject.CreatePrimitive(PrimitiveType.Sphere);
        var rigidbody = m.AddComponent<Rigidbody>();
        var x=m.AddComponent<WorldAnchor>();
        if(x as WorldAnchor)
            addcomment.comment = "added world anchor";
        else
            addcomment.comment = "not added worldanchor";
        rigidbody.velocity = Vector3.zero;
        rigidbody.constraints = RigidbodyConstraints.FreezeAll;
        m.AddComponent<MeshFilter>();
        m.AddComponent<BoxCollider>();
        m.AddComponent<MeshRenderer>();
        return m;
What have I done wrong here?
    DanglingNeuronDanglingNeuron ✭✭✭
    edited July 2016
    You are not saving the world anchor.
    You first need to get the World Anchor Store
    Then you create your anchor, if its located, you save it with an anchor id
    WorldAnchorStore anchorStore = null;
    WorldAnchor anchor = null;
    const string AnchorID = "MyFunkyAnchor";
    void Start()
    WorldAnchorStore.GetAsync(AnchorStoreReady);
        void AnchorStoreReady(WorldAnchorStore store)
            anchorStore = store;
    CreateandSaveAnchor()
    anchor = GameObject.AddComponent();
    if(anchor.isLocated)
    anchorStore.Save(AnchorID, anchor);
    Sorry I should have added that my comment output box comes up with "not added worldanchor" every time!
    Oh thank you for that very prompt reply DanglingNeuron. I have not tested what you said yet but I will do and report if it was successful for me.
    I had already started up a WorldAnchorStore but could not see how I could put a WorldAnchor into this store without it being validated. Before you can test it with isLocated property, Just testing if it was a non-null object is a good thing to do. In your example DanglingNeuron you suggested:-
    On my machine the second line just does not compile up. Even if 'anchor' is declared as a WorldAnchor, don't we have to make clear the type of Component we are adding?
            anchor=m.AddComponent<WorldAnchor>();
            if(anchor as WorldAnchor)
                    //anchor is located
                    addcomment.comment = "world anchor is located";
            else
    My comment box always reports 'Not added worldanchor".
    I apologize in advance if I am being ultra stupid here. Please be patient and try to explain my error.
    edited July 2016
    sorry that was a typo...
    anchor = yourGameObject.AddComponent< WorldAnchor >();
    but you should only check for null dont do a "cast as"
    if(anchor != null and anchor.isLocated)
    we are good to go
    Thank you for your comment about not casting it. It tried it with the amended code
            if(anchor !=null)
                    //anchor is located
            else
    but I still got the unwelcome info. I have never posted up a screen snippet before, but here's a try:-
    The units are in millimetres here. The white spheres are sample positions that are a result of going through this code body.
    Any further suggestions perhaps?
    AlexDAlexD ✭✭✭
    @wheelchairman please check my answer I provided in one of the other sections to the same problem.
    You cannot set a WorldAnchor on an object that has a Rigidbody component.
    Thanks AlexD I replied to you in the other section with a new comment thank you.
