Adding 'InternetClient' Capability causes app registration to fail when deploying to device
I'm porting an app to HoloLens that accesses the internet (using HTTP Post/Get). So in Unity I checked the 'InternetClient' Capability, but when I do so, my app fails to deploy to device. Visual Studio gives this message:
DEP0700 : Registration of the app failed. error 0x80070057: Windows cannot create the AppContainer profile for the XXXXX package. (0x80073cf6)
I get the same error trying to deploy to the HoloLens emulator. If I uncheck that capability, it loads fine (but fails to access the internet). Any ideas?
Here's the full deploy output:
4>------ Deploy started: Project: XXXXX, Configuration: Release x86 ------
4>Updating the layout...
4>Copying files: Total 32 mb to layout...
4>Checking whether required frameworks are installed...
4>Registering the application to run from layout...
4>DEP0700 : Registration of the app failed. error 0x80070057: Windows cannot create the AppContainer profile for the XXXXXX package. (0x80073cf6)
========== Build: 3 succeeded, 0 failed, 0 up-to-date, 0 skipped ==========
========== Deploy: 0 succeeded, 1 failed, 0 skipped ==========
I figured it out. I dunno why I don't have the problem unless InternetClient (or InternetClientServer) enabled, but the problem was the package display name (Product Name in Unity) had an invalid character in it, |. I removed that, and my app installed and ran.
Try an uninstall the app first. Maybe that helps.
Unfortunately, it didn't help - the app isn't installed on either the emulator or the device, yet the same problem. I can push to device without the InternetClient permission, but not with it.
