Enable installing app from Store on HoloLens
AdamK
I've got an app in the Store which is available for Windows 8 and Windows Phone 8. I'm developing a Windows 10 UWP app with the same package identity, and using a flight to distribute it to select users. I can install and run the app from the Store on PC and Mobile, but I cannot install the app via the Store onto the HoloLens.
Do I need to do something special to enable this?
The app doesn't have any special requirements. Min SDK version is 10240.
I was able to deploy to HoloLens via Visual Studio remote debugging.
@AdamK,
I believe you will need to check the Holographic box in your app submission for it to be visible on HoloLens. The check boxes are in the Pricing and availability section under Windows 10 device families.
David
@Adamk yes, you need to mark your app for the Holographic platform as mentioned in this thread and this one.
