SpeechManager: Can I add any keywords as commands?
I was following along with the 100E tutorial and wanted to incorporate voice commands into my program. Am I able to use any words that I want? I tried replacing the command I wanted and called the appropriate method to carry out the behavior, but it doesn't seem to work. I included the code that I was following as well as my code below.
From the Tutorial 100E:
void Start () { keywords.Add("Reset world", () => { //Call the OnReset Method on every descendent object this.BroadcastMessage("OnReset"); }); keywords.Add("Drop sphere", () => { var focusObject = GazeGestureManager.Instance.FocusedObject; if(focusObject != null) { //Call the OnDrop method on just the focused object focusObject.SendMessage("OnDrop"); } });
My code:
void Start() { /*keywords.Add("Reset world", () => { // Call the OnReset method on every descendant object. this.BroadcastMessage("OnReset"); });*/ keywords.Add("Rotate handle", () => { var focusObject = GazeGestureManager.Instance.FocusedObject; if (focusObject != null) { // Call the OnRotate method on just the focused object. focusObject.SendMessage("OnRotate"); } });
OptionsJesse_McCulloch admin
So, to close this issue out, here were the findings. There was both a SpeechManager and a DictionManager that were competing for use of the microphone. When I disabled the DictionManager, the SpeechManager was able to recognize the keyword. The second problem was that the SpeechManager method for the keyword was using the SendMessage method rather than the SendMessageUpward method, which caused a problem in that the object that held the command was not the object in focus, but a parent GameObject.
6
That should be working. Have you tried throwing a breakpoint in to see if it's recognizing your command? Maybe put it on the line that reads
@Jesse_McCulloch Thanks for you response. I just tried it using the Hololens device and it's not working (it doesn't go to the break point, so it doesn't seem to be recognizing my voice command). I also checked the microphone capability and it is on. Is there something special I need to add for it to pick up certain speech commands?
Sorry, that advice I gave you was bad advice. That breakpoint would not get hit, because all you are doing is adding an anonymous method to the keyword dictionary.
You want to put a breakpoint in
private void KeywordRecognizer_OnPhraseRecognized
in your KeywordManager script
The tutorial that I was following doesn't have a KeywordManager script. Do I need to have that? What does it contain?
Sorry, I thought you were using the HoloToolkit. Which tutorial are you following?
100E https://developer.microsoft.com/en-us/windows/holographic/holograms_101e
Should I be using the HoloToolkit? I was trying to find the easiest way to incorporate my own voice commands
Ok, so in your speechmanager script, you should have a method called KeywordRecognizer_OnPhraseRecognized. That's where you want your breakpoint
