DirectX: rendering via two RenderTargetViews
EgorboEgorbo
Hello, the official doc says:
If you want to render without using stereo instancing, you will need to create two non-array RenderTargetViews (one for each eye) that references the two slices in the Texture2DArray provided to the app from the system (this is not recommended as it is typically significantly slower than using instancing).
Is there any example of how to achieve it?
I mean in my code I do
device->CreateRenderTargetView(backbufferTexture, 0, &defaultRenderTargetView);
where backbuffer is obtained from the Holoframe and it all works fine but renders only to the left eye. Can you please help me how to render to the right one?
I suspect I should configure D3D11_RENDER_TARGET_VIEW_DESC but I can't find working parameters :disappointed:
  • edited August 2016
    Hi @Egorbo,
    Basically what the documentation is saying that you shouldn't do this for performance reasons, but if you must...
    After re-reading, I edited my post. You basically have to draw twice. You'll need to draw to the first render target or basically Render(), then again with the next view. For each view it needs to have it's view ports set appropiately.
    Another thing you could do if you do want to use instanced drawing, is modify your shaders to duplicate your rendering to both views. You can do this using your geometry shader and tell it to alternate between 0 and 1 for your Render target array.
    For your Shader in instanced drawing check this post?
    Dwight Goins
    http://dgoins.wordpress.com
  • EgorboEgorbo
    edited August 2016
    @Dwight_Goins_EE_MVP Thanks, but unfortunately instanced drawing won't work for my game engine/scene. I want to try that "draw twice" solution first but I can't figure out how to create a viewport for the right eye.
  • This is good to hear. Glad to see you have it working!
    Dwight Goins
  • @Egorbo said:
    Fixed. Found how to render to the right eye:
    D3D11_RENDER_TARGET_VIEW_DESC desc;
    memset(&desc, 0, sizeof desc);
    desc.Format = DXGI_FORMAT_UNKNOWN;// textureDesc.Format;
    desc.ViewDimension = D3D11_RTV_DIMENSION_TEXTURE2DARRAY;
    desc.Texture2DArray.ArraySize = 1;
    desc.Texture2DArray.FirstArraySlice = 1;
    @Egorbo I am also Trying to do similar. Can You Please share complete sample.
