Can any one tell me which Laptop is the best for Hololens Development
in Discussion
I'm going to buy a higher end laptop, can you experts suggest a Good Laptop which will be compatible with HOLOLENS development.
Comments are Appreciable!!
Jones ✭
Thanks David!
I've tried following the Installation checklist, But there is a problem with the laptop I use
if Second Level Address Translation (SLAT) is enabled the Hyper V gets disabled automatically and if Hyper V is Enabled Second Level Address Translation (SLAT) gets disabled automatically. Can you help me sort this?
You can find my laptop specs in the below URL
http://www.cnet.com/products/dell-latitude-e5550-15-6-core-i5-5200u-4-gb-ram-500-gb-hdd/specs/
@Jones,
The development machine system requirements are documented here. As long as your PC meets the requirements for Visual Studio 2015 and the emulator (if you will be using the emulator), you should be successful.
David
Thanks David!
Hi Jones,
My understanding was that SLAT was either required or very highly recommended in order for Hyper-V to work. I wonder if while enabling SLAT the BIOS automatically enables something else that you have to manually disable?
This post seems like it may have relevant information:
http://social.technet.microsoft.com/wiki/contents/articles/3190.hyper-v-how-to-fix-bios-errors-enabling-hyper-v.aspx
Have you upgraded to Windows 10?
Thanks Patrick!
Yes I've Upgraded to Windows 10. I'm checking on HYPER V and SLAT. Let me go through the information.
Thanks David and Patrik!
I can confirm that development is also possible on a MacBook Pro running Windows 10 Pro bootcamped. However there is no explicit way to enable SLAT, you have to actively reboot with Windows boot drive selected as default which is a bit of voodoo.
