Color Square appears with Hololens emulator using Parallels 11 for Mac
AR123AR123
After the emulator opens up with the nested hyper v enabled, 8 gig's set aside, and 4 processors, it works fine for a little while, but for some reason a square colored cube appears in place of the Hololens store browser, or any browsers.
Any suggestions?
    Did you build and deploy the template application from Visual Studio? That's what appears to be running in your emulator.
    AR123AR123
    edited August 2016
    @timg Yes, I've basically followed the steps in this video. Was I not suppose to use the template from Visual Studio?
    https://www.youtube.com/watch?v=0ImaZ_Aqe3I
    Here are some of the outPuts right before the square appears:
    The thread 0xb84 has exited with code 0 (0x0).
    The thread 0xc90 has exited with code 0 (0x0).
    The thread 0xa40 has exited with code 0 (0x0).
    The thread 0xd70 has exited with code 0 (0x0).
    Also, here's the specs from the MacBookPro used; I'm pretty sure I met the system requirements.
