World Anchor persistence across application updates
It appears to me the the WorldAnchorStore is getting reset every time I redeploy my application. Are there any strategies for keeping these from version to version?
  • PatrickPatrick mod
    edited August 2016
    Do you have the checkbox that says Uninstall and Reinstall my package checked?
    if so, don't check that.
    Also, switching from debug to release will reinstall the application.
  • I was hopeful, but it isn't checked
  • Okay, I'll see if it's working for me. Might be a bit...
  • yeah, so that is actually a Windows 10 anniversary update feature. I think I have it working now. Appreciate the help.
  • okay, that explains why my home machine didn't have the option. :) Now I have to figure out why my home machine isn't running AU. :)
