Using WPF UI components in Hololens
Hi, I have some UI components in WPF that I would like to use in HoloLens. It's looking like this is not possible - this WPF application for HoloLens. Do I have to redevelop my WPF app for the HoloLens?
OptionsDavidKlineMS mod
@beerOfTheRootVariety,
WPF applications are not Universal Windows Platform applications. You will need to rewrite your application to be a UWP app. Fortunately, this is not too difficult as both UWP apps and WPF apps can use XAML for their user interfaces. I have done this and, while not difficult, the largest amount of work is in updating code to use UWP APIs.Thanks!
David6
David
