Running emulator directly
I haven't worked with this toolchain or Hyper-V before. How do I run the emulator directly w/o deploying a specific application to it in Visual Studio?
I see it in Hyper-V and am able to run it there, but it lacks the skin and input handling. I tried running xde from command line and specifying the vhd, but that lacked the skin. Sorry for the noobery >_<
  • I know you can run it from hyper-v and connect to it from the hyper-v manager, however getting the skin is a custom ui called XDE that embeds the vm, along with the other tools windows. you have to properly launch the XDE using the parameters that point to your Hololens VM. Here's an example on windows Phone emulators a little research i'm sure you can figure out the commands for Hololens vhd.
    Dwight Goins
    http://dgoins.wordpress.com
  • thank you! I learned the way to get at command vs is running is with sysinternals procexp if anyone was curious.
  • yep.
    Dwight Goins
  • wintermootwintermoot ✭✭
    edited April 2016
    nm, all set
  • @Dwight_Goins_EE_MVP said:
    "C:\Program Files (x86)\Microsoft XDE\10.0.11082.0\XDE.exe" /name "HoloLens Emulator 10.0.11082.1039.dngoins" /displayName "HoloLens Emulator 10.0.11082.1039" /vhd "C:\Program Files (x86)\Windows Kits\10\Emulation\HoloLens\10.0.11082.1039\flash.vhd" /video "1268x720" /memsize 2048 /language 409 /creatediffdisk "C:\Users\dngoins\AppData\Local\Microsoft\XDE\10.0.11082.1039\dd.1268x720.2048.vhd" /fastShutdown /sku HDE
    I wrote this command into Command Prompt (in Admin mode) and after the emulator opened I got an error message said 'The emulator is unable to verify that the virtual machine is running: Invalid signature for registry bin.'
    edited June 2016
    Here is a new version for the May 2016 First flight. Copy to notepad and replace c:\User\jimsh\ with your username path
    "C:\Program Files (x86)\Microsoft XDE\10.0.14342.0\XDE.exe" /name "HoloLens Emulator 10.0.14342.1018.jimsh" /displayName "HoloLens Emulator 10.0.14342.1018" /vhd "C:\Program Files (x86)\Windows Kits\10\Emulation\HoloLens\10.0.14342.1018\flash.vhd" /video "1268x720" /memsize 2048 /language 409 /creatediffdisk "C:\Users\jimsh\AppData\Local\Microsoft\XDE\10.0.14342.1018\dd.1268x720.2048.vhd" /fastShutdown /sku HDE
    Open a Command line "Run As Administrator" and paste in the updated command above,press enter, wait 180 seconds until HoloLens Emulator blooms.
    I have the same problem. Also if I try to launch again from Visual Studio, it keeps popping out this error. It seems that I corrupted the emulator maybe. Have you found a solution?
    This solution worked perfectly for me.
  • when i try to launch emulator directly i get the following error "The emulator is unable to create differencing disk: The system cannot find the path specified". Any one else have that problem?
  • mike_smike_s
    edited March 2018
    Just for people who stumble across this post, I made a few edits. Replaced a lot of the account specific things with the corresponding windows environment variables.
    Put the below in a .bat file, double click on it to run. Update xde_version or emu_version to match your installed versions.
    It will complain if you haven't launched it with VS previously to create the diffdisk, which could be fixed with a change to the creatediffdisk paramater, or creating the directory if it does not exist.
    set xde_version=10.0.14393.0
    set emu_version=10.0.14393.1358
    "%programfiles(x86)%\Microsoft XDE\%xde_version%\XDE.exe" /name "HoloLens Emulator %emu_version%.%username%" /displayName "HoloLens Emulator %emu_version%" /vhd "%programfiles(x86)%\Windows Kits\10\Emulation\HoloLens\%emu_version%\flash.vhd" /video "1268x720" /memsize 2048 /language 409 /creatediffdisk "%localappdata%\Microsoft\XDE\%emu_version%\dd.1268x720.2048.vhd" /fastShutdown /sku HDE
