StreamSocketListener problems on real device
I'm using a StreamSocketListener to listen for incoming TCP connections in a 2D UWP app. This works absolutely fine when running the app on the local computer and it also works fine in the HoloLens emulator. However, I'm unable to make connections to the real HoloLens device.
I'm broadcasting the TCP port using UDP into the network and I can see the messages from the device, so it's not an issue of the network itself. The device also has internet access.
Can anyone help me with this? Thanks!
    Is your project simple enough to share?
    front line triage:
    1. have you enabled the internetclientserver and privatenetworkclientserver capabilities?
    2. Does everything work fine from a PC on wifi?
    3. Have you run the app under the debugger on the HoloLens to see if the debugger output has a clue?
    Hi Patrick,
    thanks for your prompt reply. I'll see if I can simplify the project enough to be able to share it.
    1. Yes, both capabilities are enabled.
    2. The PC is on a wired connection, it works there, but I can't test it with WiFi
    3. No output that indicates a problem. I tried different ports with no success. I did try port 80 once, which then caused an exception. So that works at least.
    MongrelMongrel
    edited August 2016
    I have created sample projects illustrating the problem. I also reversed the whole connection process (listen for UDP broadcast on the HoloLens, trying outbound TCP connection), but I was unable to receive the UDP broadcast on the device. Again, everything works fine on the PC and emulator.
    Therefore, I assume, that the device drops the packets for some reason. Is there a configurable firewall on the HoloLens?
    Regarding the sample projects: If you point to a place where I could upload them, that would be nice.
    Sometimes I think there is a secret electronics union. I'm waiting for Pixar to make a movie about it.
