Emulator fails using Parallels for Mac
AR123AR123
edited August 2016 in Discussion
Been getting this strange cube colored square after a few seconds running the emulator.
Seems that files are missing, or fail to load:
'New.exe' (Win32): Loaded 'C:\Windows\System32\windows.storage.dll'. Cannot find or open the PDB file.
'New.exe' (Win32): Loaded 'C:\Windows\System32\powrprof.dll'. Cannot find or open the PDB file.
'New.exe' (Win32): Loaded 'C:\Windows\System32\shlwapi.dll'. Cannot find or open the PDB file.
'New.exe' (Win32): Loaded 'C:\Windows\System32\profapi.dll'. Cannot find or open the PDB file.
'New.exe' (Win32): Loaded 'C:\Windows\System32\iertutil.dll'. Cannot find or open the PDB file.
'New.exe' (Win32): Loaded 'C:\Windows\System32\urlmon.dll'. Cannot find or open the PDB file.
'New.exe' (Win32): Loaded 'C:\Windows\System32\cryptbase.dll'. Cannot find or open the PDB file.
'New.exe' (Win32): Loaded 'C:\Windows\System32\BCP47Langs.dll'. Cannot find or open the PDB file.
DXGI WARNING: IDXGIFactory::CreateSwapChain: DXGI_SWAP_CHAIN_DESC.OutputWindow is not a valid window handle. [ MISCELLANEOUS WARNING #65: ]
'New.exe' (Win32): Loaded 'C:\Windows\System32\propsys.dll'. Cannot find or open the PDB file.
Original Post
http://forums.hololens.com/discussion/2013/color-square-appears-with-hololens-emulator-using-parallels-11-for-mac#latest
    Why bother with running a VM inside a VM? I would suggest booting all the way into Windows and not using parallels.
