World coordinates from meshes (VertexPositions->Data)
Hello,
I am trying to extract spatial meshes to an array of global coordinates, how can I extract them from mesh->VertexPositions->Data ? I don't need to render them so I don't want to do "CreateDirectXBuffer" stuff like in samples. PS: I am not using Unity.
auto options = ref new SpatialSurfaceMeshOptions(); auto formats = options->SupportedVertexPositionFormats; options->VertexPositionFormat = DirectXPixelFormat::R16G16B16A16IntNormalized; auto mapContainingSurfaceCollection = m_surfaceObserver->GetObservedSurfaces(); for (auto& pair : mapContainingSurfaceCollection) { auto const& surfaceInfo = pair->Value; auto mesh = co_await surfaceInfo->TryComputeLatestMeshAsync(1000, options); auto positions = mesh->VertexPositions->Data; //IBuffer to Vector3[]?.. }
IBuffer is just a WinRT Wrapper around a BYTE *, so cast it to a BYTE *, then iterate through the array of Bytes.
Each byte represents an x,y,z,w Float, if I remember correctly.
Something like this:
Dwight Goins
http://dgoins.wordpress.com
@Dwight_Goins_EE_MVP Thank you so much for help!!
what is verticesCount in your code? is it mesh->VertexPositions->ElementCount? if so why it's divided by m_normalStride? Thanks!
PS: do these options work with your code?:
Vertices Count is : auto verticesCount = m_surfaceMesh->VertexPositions->ElementCount;
I was doing something else - in your case don't divide by the stride. I gave a general idea on how to get the IBuffer data for the Positions. Again it's a Byte *. So that means you have to read the Byte * and for each byte convert it to the data you need. If the format is 2 byte, then that means every 2 Bytes you need to read it as 1 double.
Your format is a 2Byte value for each element. 16bits for Red, 16 for Green, 16 for Blue and 16 for alpha. Each value in the 2Byte will be a float from 0.00 to 1.00 (Normalized from 0 to 255) with 0.00 = 0 and 1.00 = 255.
HTH
Dwight Goins
I think this is what you need. I extracted it from a test project I use, so there might be some noise:;
I also found that you might have to multiply each vertex by
m_surfaceMesh->VertexPositionScale
and then transform each vertex by
where currentCoordinateSystem was obtained as a Stationary SpatialCoordinateSystem.
Finally, I was using sample code where DirectX stored the vertices in the DXGI_FORMAT_R16G16B16A16_SNORM format (not sure if you can change this), so I had to extract the actual vertices as follows:
Based on the information found in this post, I wrote some code to access the surface mesh vertex information. Problem is that I sometimes get an error "Access violation reading location 0x00E01000" (location varies) when attempting to read q[4*i] (see below). Anyone has an explanation for that error to occur?
int vertexCount = m_surfaceMesh->VertexPositions->ElementCount; short *q = (short *)m_surfaceMesh->VertexPositions->Data; for (int i = 0; i < vertexCount; i++) // goes through all vertices of the mesh { short xc = q[4 * i]; short yc = q[4 * i+1]; short zc = q[4 * i+2]; }
Is it expected to work that IBuffer can be cast to short(star)? That would be very convenient, but I don't think that you can know the memory layout of the Data object. I hope I'm wrong, because I would so much rather treat IBuffers like void(star)? 's.
I posted in this thread how I get the actual data pointer from the buffer. Do you still have the same problem if you follow that approach?
thank you Patrick. That was the problem. I had not noticed the IBuffer cast. It did work about 90% of the time though, which is not good enough by a long shot.
