World coordinates from meshes (VertexPositions->Data)
Hello,
I am trying to extract spatial meshes to an array of global coordinates, how can I extract them from mesh->VertexPositions->Data ? I don't need to render them so I don't want to do "CreateDirectXBuffer" stuff like in samples. PS: I am not using Unity.
auto options = ref new SpatialSurfaceMeshOptions();
auto formats = options->SupportedVertexPositionFormats;
options->VertexPositionFormat = DirectXPixelFormat::R16G16B16A16IntNormalized;
auto mapContainingSurfaceCollection = m_surfaceObserver->GetObservedSurfaces();
for (auto& pair : mapContainingSurfaceCollection)
    auto const& surfaceInfo = pair->Value;
    auto mesh = co_await surfaceInfo->TryComputeLatestMeshAsync(1000, options);
    auto positions = mesh->VertexPositions->Data;
    //IBuffer to Vector3[]?..
    edited August 2016
    IBuffer is just a WinRT Wrapper around a BYTE *, so cast it to a BYTE *, then iterate through the array of Bytes.
    Each byte represents an x,y,z,w Float, if I remember correctly.
    Something like this:
        // First, we acquire the raw data buffers.
            Windows::Storage::Streams::IBuffer^ positions = m_surfaceMesh->VertexPositions->Data;
            Windows::Storage::Streams::IBuffer^ normals = m_surfaceMesh->VertexNormals->Data;
            Windows::Storage::Streams::IBuffer^ indices = m_surfaceMesh->TriangleIndices->Data;
    BYTE * ptrNormals = (BYTE *)normals;
            // Finally, we cache properties for the buffers we just created.
            m_vertexStride = m_surfaceMesh->VertexPositions->Stride;
            m_normalStride = m_surfaceMesh->VertexNormals->Stride;
                auto numOfVertices = (UINT)(verticesCount / m_normalStride);
                for (UINT i = 0; i < numOfVertices; i++)
                    auto fred = (float) *ptrNormals;
                    ptrNormals++;
                    auto fgreen = (float)*ptrNormals;
                    ptrNormals++;
                    auto fblue = (float)*ptrNormals;
                    ptrNormals++;
                    auto fAlpha = (float)*ptrNormals;
                    ptrNormals++;
                    XMFLOAT3 normal = XMFLOAT3(fred, fgreen, fblue);
                    auto fX = (float)*ptrPositions;
                    ptrPositions++;
                    auto fY = (float)*ptrPositions;
                    ptrPositions++;
                    auto fZ = (float)*ptrPositions;
                    ptrPositions++;
                    auto fW = (float)*ptrPositions;
                    ptrPositions++;
                    XMFLOAT3 position = XMFLOAT3(fX, fY, fZ);
                    XMFLOAT2 texture;
                    texture.x = textureCoords.at(i).x;
                    texture.y = textureCoords.at(i).y;
                    vertices.push_back(VertexPositionNormalTexture(XMFLOAT3(position.x, position.y, position.z), XMFLOAT3(normal.x, normal.y, normal.z), XMFLOAT2(texture)));
    Dwight Goins
    http://dgoins.wordpress.com
    EgorboEgorbo
    edited August 2016
    @Dwight_Goins_EE_MVP Thank you so much for help!!
    what is verticesCount in your code? is it mesh->VertexPositions->ElementCount? if so why it's divided by m_normalStride? Thanks!
    PS: do these options work with your code?:
    options->IncludeVertexNormals = true;
    Vertices Count is : auto verticesCount = m_surfaceMesh->VertexPositions->ElementCount;
    I was doing something else - in your case don't divide by the stride. I gave a general idea on how to get the IBuffer data for the Positions. Again it's a Byte *. So that means you have to read the Byte * and for each byte convert it to the data you need. If the format is 2 byte, then that means every 2 Bytes you need to read it as 1 double.
    Your format is a 2Byte value for each element. 16bits for Red, 16 for Green, 16 for Blue and 16 for alpha. Each value in the 2Byte will be a float from 0.00 to 1.00 (Normalized from 0 to 255) with 0.00 = 0 and 1.00 = 255.
    HTH
    Dwight Goins
    I think this is what you need. I extracted it from a test project I use, so there might be some noise:;
    float3 vertexScale = m_surfaceMesh->VertexPositionScale;
        int InputVertexCount = m_surfaceMesh->VertexPositions->ElementCount;
        float spacing = 1.0f / 12.0f;
        // convert all the verts to approximate verts
        // it would probably be better to check the surface of each triangle rather
        // than taking each vertex...
        for (int index = 0;index < InputVertexCount;index++)
            // read the currentPos as an XMSHORTN4.
            XMSHORTN4 currentPos = XMSHORTN4(rawVertexData[index]);
            XMFLOAT4 xmfloat;
            // XMVECTOR knows how to convert the XMSHORTN4 to actual floating point coordinates.
            XMVECTOR xmvec = XMLoadShortN4(&currentPos);
            // STore that into an XMFLOAT4 so we can read the values.
            XMStoreFloat4(&xmfloat, xmvec);
            // WHich need to be scaled by the vertex scale before approximating.
            XMFLOAT4 scaledVector = XMFLOAT4(xmfloat.x*vertexScale.x, xmfloat.y*vertexScale.y, xmfloat.z*vertexScale.z, xmfloat.w);
            // Then we need to down scale the vector since it will be rescaled when rendering
            float4 nextFloat = float4(scaledVector.x, scaledVector.y, scaledVector.z, scaledVector.w);
            localRawVoxels->Append(nextFloat);
            nextFloat = ConvertToApproximateVector(nextFloat, spacing);
            m_rawVoxels->Append(nextFloat);
    XMSHORTN4* rawVertexData = (XMSHORTN4*)GetDataFromIBuffer(m_surfaceMesh->VertexPositions->Data);
    template <typename t = byte>
    t* GetDataFromIBuffer(Windows::Storage::Streams::IBuffer^ container)
        if (container == nullptr)
            return nullptr;
        unsigned int bufferLength = container->Length;
        if (!(bufferLength > 0))
            return nullptr;
        HRESULT hr = S_OK;
        ComPtr<IUnknown> pUnknown = reinterpret_cast<IUnknown*>(container);
        ComPtr<IBufferByteAccess> spByteAccess;
        hr = pUnknown.As(&spByteAccess);
        if (FAILED(hr))
            return nullptr;
        byte* pRawData = nullptr;
        hr = spByteAccess->Buffer(&pRawData);
        if (FAILED(hr))
            return nullptr;
        return reinterpret_cast<t*>(pRawData);
    I also found that you might have to multiply each vertex by
    and then transform each vertex by
    SpatialCoordinateSystem^ scs = m_surfaceMesh->CoordinateSystem;
    Platform::IBox<float4x4>^ scsToWorld = scs->TryGetTransformTo(currentCoordinateSystem);
    vertex = transform(vertex, scsToWorld->Value);
    where currentCoordinateSystem was obtained as a Stationary SpatialCoordinateSystem.
    Finally, I was using sample code where DirectX stored the vertices in the DXGI_FORMAT_R16G16B16A16_SNORM format (not sure if you can change this), so I had to extract the actual vertices as follows:
    float* vertices = new float[m_numberOfVertexPositions*3];
    for (int i = 0; i < m_numberOfVertexPositions; i++)
        short x = (raw_vertices[i * 4 + 0]);
        short y = (raw_vertices[i * 4 + 1]);
        short z = (raw_vertices[i * 4 + 2]);
        short w = (raw_vertices[i * 4 + 3]);
        float xx = (x == -32768) ? -1.0f : x * 1.0f / (32767.0f);
        float yy = (y == -32768) ? -1.0f : y * 1.0f / (32767.0f);
        float zz = (z == -32768) ? -1.0f : z * 1.0f / (32767.0f);
        float ww = (w == -32768) ? -1.0f : w * 1.0f / (32767.0f);
        float3 vertex = float3(xx * scale.x, yy * scale.y, zz * scale.z);
        vertices[i*3 + 0] = vertex.x;
        vertices[i*3 + 1] = vertex.y;
        vertices[i*3 + 2] = vertex.z;
    MarcDubMarcDub ✭✭
    edited September 2016
    Based on the information found in this post, I wrote some code to access the surface mesh vertex information. Problem is that I sometimes get an error "Access violation reading location 0x00E01000" (location varies) when attempting to read q[4*i] (see below). Anyone has an explanation for that error to occur?
    int vertexCount = m_surfaceMesh->VertexPositions->ElementCount; short *q = (short *)m_surfaceMesh->VertexPositions->Data; for (int i = 0; i < vertexCount; i++) // goes through all vertices of the mesh { short xc = q[4 * i]; short yc = q[4 * i+1]; short zc = q[4 * i+2]; }
    PatrickPatrick mod
    Is it expected to work that IBuffer can be cast to short(star)? That would be very convenient, but I don't think that you can know the memory layout of the Data object. I hope I'm wrong, because I would so much rather treat IBuffers like void(star)? 's.
    I posted in this thread how I get the actual data pointer from the buffer. Do you still have the same problem if you follow that approach?
    MarcDubMarcDub ✭✭
    thank you Patrick. That was the problem. I had not noticed the IBuffer cast. It did work about 90% of the time though, which is not good enough by a long shot.
