Extracting camera position, direction and up from HolographicStereoTransform
Hello,
I'm trying to extract cameras information of each eye from HolographicStereoTransform
The following code works inside the emulator, but doesn't with the real hololens.
Do you have an idea of what's wrong ?
HolographicStereoTransform cameraProjectionTransform = cameraPose.ProjectionTransform; HolographicStereoTransform? viewTransformContainer = cameraPose.TryGetViewTransform(coordinateSystem); if (viewTransformContainer.HasValue) { HolographicStereoTransform viewTransform = viewTransformContainer.Value; Matrix4x4 ReversedMatrix; if(Matrix4x4.Invert(viewTransform, out ReversedMatrix)) { Camera.Position.X = ReversedMatrix.M41; Camera.Position.Y = ReversedMatrix.M42; Camera.Position.Z = ReversedMatrix.M43; Camera.Direction.X = -ReversedMatrix.M31; Camera.Direction.Y = -ReversedMatrix.M32; Camera.Direction.Z = -ReversedMatrix.M33; Camera.Up.X = -ReversedMatrix.M21; Camera.Up.Y = -ReversedMatrix.M22; Camera.Up.Z = -ReversedMatrix.M23; } const float Rad2Deg = 57.295779f; // 180/PI float E = cameraProjectionTransform.M22; Camera.FieldOfView = ((float)Math.Atan(1/E) * 2) * Rad2Deg; }
Patrick mod
I put this in the render loop of the spinning cube template, and it seems to work on emulator and in device.
HolographicStereoTransform cameraProjectionTransform = cameraPose->ProjectionTransform; IBox<HolographicStereoTransform>^ viewTransformContainer = cameraPose->TryGetViewTransform(m_referenceFrame->CoordinateSystem); if (viewTransformContainer != nullptr) { HolographicStereoTransform viewTransform = viewTransformContainer->Value; XMMATRIX revMat = XMMatrixInverse(nullptr, XMLoadFloat4x4((const float4x4*)&viewTransform.Left)); float4x4 floatMat; XMStoreFloat4x4(&floatMat, revMat); WCHAR msg[255]; swprintf_s(msg, L"LEFT\n%.02f %.02f %.02f\n%.02f %.02f %.02f\n%.02f %.02f %.02f\n%.02f\n", floatMat.m41, floatMat.m42, floatMat.m43, floatMat.m31, floatMat.m32, floatMat.m33, floatMat.m21, floatMat.m22, floatMat.m23, (atan(1 / cameraProjectionTransform.Left.m22) * 2 * 57.295779f)); OutputDebugString(msg); revMat = XMMatrixInverse(nullptr, XMLoadFloat4x4((const float4x4*)&viewTransform.Right)); XMStoreFloat4x4(&floatMat, revMat); swprintf_s(msg, L"RIGHT\n%.02f %.02f %.02f\n%.02f %.02f %.02f\n%.02f %.02f %.02f\n%.02f\n\n", floatMat.m41, floatMat.m42, floatMat.m43, floatMat.m31, floatMat.m32, floatMat.m33, floatMat.m21, floatMat.m22, floatMat.m23, (atan(1 / cameraProjectionTransform.Right.m22) * 2 * 57.295779f)); OutputDebugString(msg); }
creates output like:
LEFT
-2.74 0.52 1.30
0.89 0.30 -0.35
-0.30 0.95 0.05
17.07
RIGHT
-2.76 0.52 1.24
0.88 0.30 -0.36
-0.30 0.95 0.05
17.05or
LEFT
-0.00 -0.02 -0.10
0.00 0.22 0.97
0.00 0.97 -0.22
17.00
RIGHT
-0.00 -0.02 -0.10
0.00 0.22 0.97
0.00 0.97 -0.22
17.00on emulator.
LEFT
-2.74 0.52 1.30
0.89 0.30 -0.35
-0.30 0.95 0.05
17.07
RIGHT
-2.76 0.52 1.24
0.88 0.30 -0.36
-0.30 0.95 0.05
17.05
or
LEFT
-0.00 -0.02 -0.10
0.00 0.22 0.97
0.00 0.97 -0.22
17.00
RIGHT
-0.00 -0.02 -0.10
0.00 0.22 0.97
0.00 0.97 -0.22
17.00
on emulator.
