Unity Hololens access webservice
I am using Unity to build an app for the HoloLens that access a webservice to retrieve data.
It works fine in the Unity Editor and the data is loaded from the webservice without any problems.
The webservice is build in asmx and I generate a .cs for it using the following Unity Mono command line
wsdl MyWS.wsdl -o:MyWS.cs
When I try to build it for the HoloLens (using this tutorial: http://hololenshelpwebsite.com/Blog/EntryId/1006/HoloLens-Hello-World) the build fails with the following error:
Assets\WebClient\MyWS.cs(25,2): error CS7069: Reference to type 'Component' claims it is defined in 'System', but it could not be found
Note: Before I integrated the webservice, I was able to build and export to the HoloLens.
I keep searching on the net, but so far every potential solution I found failed.
Is it actually possible to access a webservice from the HoloLens?
OptionsZorglub ✭
I ended up completely scrapping this approach.
Instead I am using UnityWebRequest5
wsdl.exe creates an old school ASP.NET web service client that uses components (Component, IComponent, etc.) that are not supported on the Universal Windows Platform https://msdn.microsoft.com/en-us/library/windows/apps/mt185499.aspx
Instead, you can use Visual Studio to generate WCF bindings for you. Simply right-click your project then click Add > Service Reference.
Yes, I changed that.
Now instead I just generate a cs file from the WSDL and added it to the Asset\WebClient
That part works well.
But when I try to build the Windows App project from Unity, I get the following error now:
Assets\WebClient\MyOwnWS.cs(2126,79): error CS0433: The type 'AsyncCompletedEventArgs' exists in both 'System.ComponentModel.EventBasedAsync, Version=4.0.10.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' and 'System, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'
