How to add a custom image to app start page.
How do I add a custom image/Logo like the attached to app start screen?![
(https://us.v-cdn.net/6026774/uploads/editor/4t/5u8apumwctz2.jpg "")
Thank you.
1
HoloSheep mod
@Hololens77 this page of the docs might help.
I believe you are looking for the 930 x 450 Splash Screen that you will find in the Package.appxmanifest Visual Assests tab of the UWP app that is generated by Unity.
Here is another thread that talks about the images for the tile logos and mentions that you may need to restart the device for some images to update.
Thank you @HoloSheep.
I will check this and try to follow whats on the document.
@HoloSheep ,
Thank you. It worked.
In new version it didn't worked - I had to set the Splash Image>Windows>Scale 200% 1240x600pix) image, and then it showed like on screenshot you've attached
