How to add a custom image to app start page.
How do I add a custom image/Logo like the attached to app start screen?![
(https://us.v-cdn.net/6026774/uploads/editor/4t/5u8apumwctz2.jpg "")
Thank you.
    Thank you @HoloSheep.
    I will check this and try to follow whats on the document.
    @HoloSheep ,
    Thank you. It worked.
    In new version it didn't worked - I had to set the Splash Image>Windows>Scale 200% 1240x600pix) image, and then it showed like on screenshot you've attached
