Unity Origami Tutorial
I am having trouble opening origami for the tutorial. When ever I open it via unity Hololens edition (im reinstalling it right now) it says the project was opened with an older version of unity. So my version is newer. It try's reimporting but spatialmappingrendering and collider are missing. What can this be? Thanks
@ahillier said:
Hi @AliMickey2000,
The warning about the project being created with an older version of Unity can typically be ignored (just press 'OK'). The Origami project was recently updated to use the new SpatialMappingRenderer and SpatialMappingCollider components from Unity. These components are available in Unity 5.4.0f1 or newer. The current version of Unity is 5.4.0f3. If you're using a version of Unity older than 5.4.0f1, then you won't be able to find these components and you'll need to update to the latest version of Unity.forgot to say i fixed it, what i did was i cut the collider and renderer from the folder and it somewhere else. launched the program and got the error, closed it and moved them back which fixed the problem. tutorial is now finished. thank you
Hi @AliMickey2000,
