SpatialMapping.cs
Hello:
I just upgrade Visual Studio to Update 2...installed Unity for Hololens and everything else that was needed...
I started following Holograms 101E but when I open the Origami project on Unity I get some errors on the SpatialMapping.cs file...
Error CS1061 'SurfaceObserver' does not contain a definition for 'OnSurfaceChanged' and no extension method 'OnSurfaceChanged' accepting a first argument of type 'SurfaceObserver' could be found (are you missing a using directive or an assembly reference?) Origami.CSharp C:\Blag\Hololens\HolographicAcademy-Holograms-101\Origami\Assets\Holograms\Support\Spatial Mapping\SpatialMapping.cs 44 Active
Error CS7036 There is no argument given that corresponds to the required formal parameter 'onSurfaceChanged' of 'SurfaceObserver.Update(SurfaceObserver.SurfaceChangedDelegate)' Origami.CSharp C:\Blag\Hololens\HolographicAcademy-Holograms-101\Origami\Assets\Holograms\Support\Spatial Mapping\SpatialMapping.cs 54 Active
Error CS7036 There is no argument given that corresponds to the required formal parameter 'onDataReady' of 'SurfaceObserver.RequestMeshAsync(SurfaceData, SurfaceObserver.SurfaceDataReadyDelegate)' Origami.CSharp C:\Blag\Hololens\HolographicAcademy-Holograms-101\Origami\Assets\Holograms\Support\Spatial Mapping\SpatialMapping.cs 116 Active
So this doesn't seem like a library or reference problem...but stuff missing on the code itself...does anyone knows how to fix this? Is there any update file?
Greetings,
Blag.
Blag.
Developer Evangelist - Development Culture
SAP Labs Silicon Valley.
  • That makes two of us. Downloaded all the tools this afternoon, installed them and rebooted machine... Started Course 101E - Chapter 1. As soon I add the Origami content... the error in the console comes up.
    One thing I did note... the Origami project code has not been updated since a month ago... When I open Unity Hololens 5.4.0b10-HTP (64-bit) it wants to update the project because it works with older version of Unity... Still the issue seems to lie in the SurfaceObserver class... do not see any OnSurfaceChanged call
    Observer.OnSurfaceChanged += Observer_OnSurfaceChanged; Line 43 in SpatialMapping.cs
  • Saw that...I thought the Github repository might has been updated...but nope...I guess we just need to wait for the Hololens teams to update the files... -:(
    Blag.
  • I'm running into the same problem as well.
  • Glad...in a weird way...not to be the only one having this problem :) Let's hope they fix this soon...
    Blag.
  • Hi, got the same exact problem. Don't you think we should raise it to the Hololens Team?
  • I thought that is what we were doing here? LOL
  • Same problem here as well
  • I think all of us with this problem... vote up Blag's original post. Thanks!
    I'm sure the HL Team will fix this soon. In the meantime, I'd recommend just skipping ahead. Course 210 - Gaze is awesome. :)
  • LaggerLTDLaggerLTD
    edited March 2016
    I have also ran into this problem when trying to import the Origami file into Unity. This is part of the Holograms 101E tutorial here:
    https://developer.microsoft.com/en-us/windows/holographic/holograms_101e
    A solution that I found was to right click onto the Assets needed in the project window and then export them to a separate file. I did this with all the assets except the Spatial Mapping Asset and the Underworld Asset since these two contained the errors. I then created a new project in Unity and then went to Assets > Import Package and then selected each Asset that I had exported from the 101E tutorial. This allowed me to run the 101E tutorial without getting any compiling errors. Unfortunately, when I got to the second part of the lesson, Gaze, I found that I could render the cursor Asset in Unity, and it will display in the hololens, but I cannot get the cursor to move. I fear this is an issue with the script WorldCursor.cs that is on the above link, but I am not sure. I have tried attaching the script using multiple methods in Unity, and the script attaches properly and compiles, but then the cursor just sits there in front of the origami collection as if no script is attached to it at all. If anyone else would like to try this method please post below and let me know how it works out for you. I am going to try and forge ahead like james_ashley suggested and try the 210 tutorial here:
    https://developer.microsoft.com/en-us/windows/holographic/holograms_210
    I understand we've only had this tech for a day so lets try to figure this out together.
  • I appreciate the quick response Jackson. This code snippet worked perfectly for me. I copied and pasted the new code into the SpatialMapping.cs file and this fixed all the errors I had running the Origami demo. It cleared all the errors in Unity that were in the SpatialMapping file and the Underworld file as well. I can now run through all of the Holograms 101E tutorial.
  • That fixed it for me.. thanks!
  • Thanks a lot Jackson! That's awesome! :smiley: Will test it tomorrow morning :smile:
    Blag.
  • Got an error with Nuget...but solve it using this https://forums.hololens.com/discussion/comment/865#Comment_865 Now...Hololens emulator is loading! :smiley:
    Blag.
