I can't use Visual Studio's Graphic Debugger to Debug Hololens.
zwxbestzwxbest
I can use Graphic Debugger to Hololens Emulator,but when I use device to debug ,it get me stuck.
this is the error.
does anyone have a idea?thx.
    I remember I had similar issues in the past as well, but now not sure if the same or not. But the latest VS 2015 Update 3 and the latest HoloLens Emulator (14393) seems to work. Can you let us know your emulator version and the VS version?
    My vs version is vs2015 with update3.
    But Graphic Debug on Hololens Emulator works well.
    The error only happen when I debug on device.
    And this is my VS
    My vs 2015's update3 is installed after install vs2015 with update2.
    Are you a Windows insider by any chance?
    BTW, did you reboot the device? You do need to reboot the device the first time you try.
    I did have this problem on one of my PCs once. I had to uninstall VS and everything that sounded like VS, and then reinstall VS to get the graphics debugger to work.
    @Patrick ,after meet this error,I robot my device from portal,and still get error.
    But Graphic Debug on Hololens Emulator work well,I am confused.
    I just try few times again,if still,maybe I'll find sometime to reinstall VS. :D
    Okay, if you do go down the route of re-installing VS, if that doesn't work the first time, you might want to try this tool to uninstall.
