Can’t install any apps on my Hololens
OptionsIonut ✭
It didn't work.
In the end i reset the Hololens, logged in with a new Live ID and now it seems to work5
@lonut when you log into a regular Windows 10 machine with the same LiveId that you used to setup your HoloLens, are you able to access the Windows Store from that machine?
It didn't work.
Just out of curiosity does the Hololens and Dev PC need to be logged in with the same LiveId?
