Is there a way to choose which GPU Emulator runs on?
I'm currently on a Surface Book i7 w/ NVidia gpu.
When ever I try to start the Emulator - either through VS.Net Holographic project or Hyper-V, I get a kernel fault: TDR_VIDEO
The emulator then throws an error that says "Can't Start Emulator in resolution using desktop graphics card restarting using software graphics..."
What I did was go into device manager and disable the Intel HD 500 graphics card. This worked like a charm. So the question is - is there a way to select which card (gpu affinity) which the Emulator will use? Is there an option like this in Hyper-V? Or is this a bug?
Dwight Goins
http://dgoins.wordpress.com
apparently there isnt. if you have multiple gpu its going to select your default built in one. this is a hyper-v issue as the current hyper-v does not support gpu selection.
Dwight Goins
http://dgoins.wordpress.com5 -
Update: @Lance just provided me a hint on how to do this, and it worked: For those of you who have the NVidia tool, just use that. Choose the "C:\Program Files (x86)\Microsoft XDE\10.0.11082.0\XDE.exe" app and select you NVidia card. Whenever this app runs, NVidia GPU will be used exclusively for the app. This app is the windows Phone emulator, it's the same one HoloLens uses when launched from VS.Net 2015.
Dwight Goins
http://dgoins.wordpress.com6
Dwight Goins
Sounds like a nVidia driver issue. I have an Dell i7 desktop with a Radeon (two 34" curved screen Dell monitors attached via hdmi and DVI-D) and the integrated intel graphics (with a 24" dell monitor via displayPort) and the emulator works like a charm.
probably, however if i choose nvidia and disable intel, it works. if i do the reverse it works, it's only when i have both video cards enabled does it yield the error.
Dwight Goins
Dwight Goins
When I selected the XDE from that path, it shows as "Windows Phone 7 Emulator (xde.exe)". However, it would not let me select the NVIDIA gpu, only the "Integrated Graphics" option is selected and the DropDownList is disabled.
Did you take any further steps that enabled the NVIDIA option?
PS - The emulator is listed when the project type is a C++ project but not when it's a C# project. I've even launched the emulator using the C++ project, kept it running and reopened C# project, didn't work
Microsoft MVP - Windows Development
More about me and my credentials
Actually you made me revisit this...
You're right, when I had my Intel graphics disabled NVidia was selected and grayed out, but it appears once Intel is enabled, the integrated option is selected and grayed out. In any case it works for other types of apps (.exe) just not the XDE one. And overall it works for me, just not choosing the specific GPU I want for this specific app.
As far as the C# project template issue, I would run the update 2 again. Make sure your C# language and features are all selected. There appears to be an invalid project template installed for c#.
Dwight Goins
Hi everyone,
Hyper-V Settings should allow you to choose which Physical GPUs to use in Physical GPUs tab. If you have multiple GPUs, you can enable/disable any of them by clicking the "Use this GPU with RemoteFX" check box.
