Does RemoveSurfaceVertices work with SurfaceMeshesToPlanes?
gene
in Discussion
Unless I am missing something, using RemoveSurfaceVertices to cut a hole in the mesh is undone if you create a plane with SurfaceMeshesToPlanes. The plane created does not preserve the hole (presumably by creating multiple smaller planes around it). Is this something that can be configured or does it require custom code?
Optionsthebanjomatic ✭✭✭
I don't believe that is the intent of RemoveSurfaceVertices. Its purpose (as far as I understand it) is to just remove the planar areas in places where the surface planes will be so that you don't have little bits of the less-than-planar surface mesh sticking out of the walls, etc.
I think you will have to write custom code if you intend to also cut holes in the surface planes.
Thanks @thebanjomatic. RemoveSurfaceVertices does work, with some adjustment, for removing mesh that intersects another object, but definitely not a plane — so I wrote a plane slicer to handle this
How to adjustment it?> @gene said:
