move a hologram across a surface
felsiskafelsiska
edited September 2016 in Questions And Answers
TapToPlace.cs and Placeable.cs moves and slides the holograms to surfaces of real world.
using same concept of locking them to a surface, how do i move them across another 3d surface without help of spatial mapping?
similar to rotating the astronaut where only 1 axis is active during navigation, this case will be disabling 1 axis during manipulation.
  • well, all you need to do is assign the physics layer of your object with collider to the placeable's layer mask... I had to refactor the placeable for my own purposes where I removed any 'hololens" specific stuff out of it... i.e. spatial mapping.
  • a simple fix would be - if you dont want to refactor placeable code - assign the layer 31 to your object.
    thanks for replying.
    sorry didn't really get by what you meant. where do i find the placeable's layer mask?
    to assign layer 31 to object, do i need to create a new script for it?
    thanks again.
  • if I am using the GestureAction.cs which uses manipulation to move, how do I edit the script to move objects according to axis?
