App crashes while uploading anchors
edited September 2016 in Questions And Answers
The program has exited with code -1073741189 (0xc000027b).
Seems to happen when uploading anchors using the default ImportExportAnchorManager.
I've also tried uninstalling, and deleting any spaces on device as well.
Stephen Hodgson
HoloToolkit-Unity Moderator
    Are you running under the debugger? Can you switch your debug settings from managed to mixed (managed and native)? Then you might catch the crash in the debugger and get a better clue.
    Yes, I was. After switching to mixed, I wasn't able to get the ImportExportAnchors class to even show up in the output. Not sure if it didn't run, or if switching to mixed prevented the write to the log.
    Stephen Hodgson
    What is in the debugger output when running mixed? (FWIW, I always run with mixed, so that's unlikely to cause debug.log to stop working)
    When running with mixed, it never reached the point where it would upload the anchors.
    Stephen Hodgson
    Agreed. I deleted everything and started over. Works fine now haha.
    Stephen Hodgson
