Updating texture via a buffer in separate file
in Discussion
I am trying my hands on Direct X 11 template in VS 2015 in VC++. I am using: D3D11_MAPPED_SUBRESOURCE Resource and MAP and UNMAP to update texture in the Spinning Cube template. Now i have a separate file in my project where i am reading pixels from a buffer and need to upload it to this texture in spinning cube file.
I am using a struct to hold the texture data :
struct Frames{
int text_Width;
int text_height;
unsigned int text_Sz;
unsigned char* text_Data; };
Want to know how can i use this struct from a separate file to upload the texture data in my Direct X based Spinning Cube file.
or do i need to release the texture and re-create it and map it to my 3D object. Can anyone please help me out in this ?
If the pixel format and the dimensions are the same I don't think you would need to "rebuild" it, so the texture object and its views probably can be reused. On the other hand, you might need (not sure now) to release the shader view from the pixel shader texture slot by calling PSSetShaderResources with null view if any texture slot is set to that texture's view. After the update it can be set again.
To update the pixels did you try the UpdateSubresource call? It needs to be iterated for all the arrays and mip levels.
In my case I have code as follow. ColorARGB is my custom struct with ARGB uint8 values. Just replace it with the size of the matching pixel format.
Context->UpdateSubresource(pD3DTexture, D3D11CalcSubresource(nMipLevel, 0, nMipLevels), nullptr, pMipBitmap->GetData<ColorARGB*>(), nWidth * sizeof(ColorARGB), nWidth * nHeight * sizeof(ColorARGB));
Here's an example using SharpDX and C#. I'm sure you can convert it over to C++ & DirectX.
https://github.com/dngoins/HololensDXTutorials
Dwight Goins
http://dgoins.wordpress.com
