DEP0001 : Unexpected Error: -1988945906 (please healp me i cant deploi on my hololens again because
weister
i just open the project without change and this errior happen
you might need to close visual studio, delete the UWP and APP folder from your unity project, and build from Unity again.
is not working either i have all the requirement and i made some build before but today is not working
okay, if that doesn't work the next thing to try is:
1. close VS and Unity
2. in your unity project folder delete the app, uwp, temp, and library folders.
3. Start unity again.
4. Export from Unity to VS.
I am also facing the same error , can someone help me , i tried above but it wont work
Well i cant fix this error but i can deploy my game with the remote option is better,, here the link https://developer.microsoft.com/en-us/windows/holographic/using_visual_studio is work, also unity 5.5 beta you can run your game in the editor without build and here is the link https://www.youtube.com/watch?v=OVvCI5KCndw
thanks for try to help me then you are the best guys,,,
This does not solve the problem
