Windows App Certification Kit - Creating the Report error
Flarb
I can't create store packages with VS. I've updated Visual Studio, built a new project from Unity, renamed the icons so the store package compiles. However, when submitting to the store, the Windows App Certification Kit fails at "Creating the Report" with a generic error "An error occurred while generating the report". There's no info in the console. How do I get this report to generate? Can I try running less tests?
@Flarb ,
From the screen capture, it looks like it has finished the test but is failing when it tries to save the report. Have you checked folder permissions or tried running as Admin?
@james_ashley No dice--ran in administrator mode, still fails.
Sorry. You can always submit anyways. You've effectively done your due diligence and the kit isn't cooperating.
