Can HoloLens recognize a specific device (tube lights, fans etc.)
The app will recognize a specific device and show menu to perform different operations. Please advise how it can be done?
    Check the iOT forums how to connect the home automation/smartdevices to windows 10. There are 2 standards which I can not recall the names now.
    For HLens to recognize a specific device - you can use computer vision techniques to recognize shapes and rudimentary objects like tables, chairs, balls, and most likely fans etc. However to recognize more specific things light tube lights compared to some other light will require custom Machine Learning algorithms that you and your team must figure out.
    You can use Open CV with C# to handle the object recognition.
    As far as connecting to IOT, @HoloDevices is speaking of AllJoyn, Z-Wave, MQTT, CoAP, there's too many to list.
    Dwight Goins
    http://dgoins.wordpress.com
    Thanks Dwight. missed "obj recognition".
    edited September 2016
    Thanks for advise.
    At the moment, we do not have HoloLens device and expecting to receive it in a couple of weeks. So just wondering if HoloLens can read a QR code from distance around 10 meters.
    As Dwight suggested, we would be looking into custom Machine Learning Algorithm. But just to start, we may club QR code scanning with shape recognition.
    Also, please comment if this will be a nice idea?
