Why is my HoloLens recording at 480? It used to record at 720.
Yes, it used to record video at 720. Now it's recording at 480. Seems this occurred since the big update. Not sure exactly. Can someone clarify?
  • @spinteractive,
    You should be able to reset to 720p using the 'Mixed Reality Capture' page on the Windows Device Portal.
    Note: this setting did not change on my HoloLens after taking the update.
  • Yes that should do it. Not sure why it got set back to 480. Thank you for the tip!
  • spinteractivespinteractive
    edited October 2016
    What I found is that when I upload to youtube is changes it to 480 and when I upload to facebook it's 720. That's because the actual video size is 1281x 684 - just shy of 720.
