"Chapter 6 - Spatial mapping" can't see wireframe
Hi all,
I followed the instructions on Chapter 6 but i can't see the wireframe. when emulator starts I see that the room is being being rendered. However, when placing cursor on the paper and pressing "space bar" i don't see wireframe.
I am using Unity 5.4.0f3-HTP. I following all posts in the forum but nothing works.
I appreciate your help,
Optionserany ✭
Ok, found the solution!!!
It seems that "SpatialPerception" must be checked before visual studio project was exported(created). In case it was created before adding this capability, this capability must be set manually in the "package.appxmanifest".
Following links describes this:
1. https://developer.microsoft.com/en-us/windows/holographic/spatial_mapping_in_unity in section "Setting the SpatialPerception capability"
2. https://developer.microsoft.com/en-us/windows/holographic/Spatial_mapping_in_DirectX.html#set_up_your_app_to_use_the_spatialperception_capability in section "Set up your app to use the spatialPerception capability"Same thing should be for voice gestures. the capability "Microphone" must be set in Unity before project was exported, otherwise, add it in "package.appxmanifest" manually. Now this also works!!!
I just wish MS would update the chapter.5
