Is it possible to give haptic feedback when we touch a Hologram
Is it possible to give haptic feedback when we touch a Hologram? If we can implement something like it, that will be cool.
utekai ✭✭✭
The holographic academy offers an example of using spatial sound to provide haptic feeedback. See course 220, Ch. 4, which has an objective to: Use sounds to replace tactile feedback of physical objects.
The feedback is based on gaze and gesture (you've gazed at an object and then finger tapped to select it). There doesn't appear to be an api or sensor feedback to closely detect when the hologram's space has been invaded, say for instance if you reach out and to touch the hologram's space. The gaze api can detect when your gaze is directed via raycast to a hologram's space.
The app 'Fragments' directs the user to come and stand in a particular spot and can detect, roughly, when the user is in that spot.
6
If you use some very efficient ear plugs to make sure you only receive the bone-conducted component of a sound and then play a deep bass-y sound on the HoloLens when something collides with you head this could hypothetically be perceived as haptic. But I've just made it up, no promises
Thank you @utekai
Also wanted to add, the main camera can have Depth Of Field component added (from Standard Assets) and will give visual indication of how close to the hologram the user is, based on the FocalDistance of the DepthOfField component. If set short, when the user is close enough to the hologram it becomes fully focused.
But this only let's the user know, but doesn't inform the hologram .
To autodetect proximity so the hologram will be informed, here's an idea ...
I've not tried it yet (newbie with Unity), but think a Point Light source that follows the Main camera could be used here in some way, or the Point Light Source could alternatively be attached to the top or midpoint of the hologram. Since the Point Light source has an adjustable Range, it could be set to a short range (say .1f), and when that point light is detected (either by the hologram or by the main camera depending on where it's attached), it could be assumed the user is close enough to the hologram. This requires that a light sensor be available to detect the Point Light source. Maybe using Pixels to sense when the specific light from the Point Light is hitting the Pixel under observation. Else using RayCasts.
And then found this, which has asks the same general question about light detection, with an answer of using Pixels to detect the light. So it's possible. Code sample too.
Also raycasts are limited to the gaze point I think. Whereas the light detection might be able to go 360 degrees. So if a hologram moved into the user's space, even if the user wasn't looking, the user or hologram could be informed.
