Difficulty in setting up HoloGrams 100 tutorial
ctsholo
Hello all,
I experienced a couple of problems while following HoloGrams 100 tutorial
1. Unity showing these warnings in console after Build
2. The Visual studio solution was outside the App folder like this
3. Visual studio solution was empty
And this is my VS version
And this is my Unity Version
In HoloGrams 100 Tutorial am stuck in Chapter 4 sub topic - "Export the visual studion Solution"
So where exactly am I going wrong? Help is very much appreciated. Thanks
Make sure you open the solution that was created in the App directory. Two are created for some reason, but I'm not well versed enough in Visual Studio to tell you why that is.
@paradoxymoron Thanks for the reply. I forgot to mention that the "App" folder is empty.
It looks like you put it in the folder called UWP (guessing). It has the same date.
Alternatively, just export to visual studio again from Unity and keep track of which folder you are creating the new project in.
@james_ashley Thanks for the reply. Again the UWP project has these files
And am pretty sure that I selected the App folder for exporting from Unity. I tried it multiple number of times and I get the same errors mentioned above in the screenshots. I tried Unistalling / repairing Visual Studio 15. Now I thinking to uninstall VS15 install VS community edition.
@ctsholo the Enterprise version of VS should work fine.
Have you checked to see if you have the UWA dev tools feature installed in your Visual Studio?
When you Build in Unity what does your build settings screen look like? have you switched the platform to Windows Store and set the SDK to Windows 10?
@HoloSheep I checked for UWA dev tools, seems it was not installed in my VS. And when I tried this was the result I got
Any workaround for this?
@ctsholo you might try the suggestions from here.
