Where is the WorldAnchor component in Unity?
DConsolo
Hey guys,
This is a bit silly. I downloaded everything from the HoloLens site and got a basic scene working from Unity perfectly on the HoloLens. I also installed the HoloToolkit, and got a bunch of errors in the "Sharing" folders. I'm having trouble finding the WorldAnchor component in Unity, what step am I missing? Are there any more toolkits I should download? Thanks!
OptionsHoloSheep mod
@DConsolo the WorldAnchor type is in the namespace:
using UnityEngine.VR.WSA;
is that what you are after?
When you say you are getting errors with the "Sharing" folder, what errors are you getting?
When you installed the HoloToolkit did you also copy over the .rsp files?
WinHUGR YouTube Channel -- live streamed meetings1
Yes! I was trying to recreate the scripts from here: https://developer.microsoft.com/en-us/windows/holographic/world_anchor_in_unity
And I failed to see the Namespace: UnityEngine.VR.WSA on the top of the page. Works now.
I'm getting the "Unsafe" command errors, and I did copy over the .rsp files. The link you provided is showing solutions for those errors. I will attempt to try these solutions.
Thanks!!
