VNCaster: VNC for Hololens
DaekenDaeken
edited September 2016 in Projects
This app has been a while in the making. It's a 100% brand new VNC client, exclusively for Hololens, compatible with all VNC servers I've tested. It does require a bluetooth keyboard, and a mouse is also highly recommended. With this, I'm finally able to ditch my laptop entirely -- OS X works great with it!
To kick things off, here are 5 promo codes to get the app for free and save $10:
http://go.microsoft.com/fwlink/?LinkId=532540&mstoken=3XJTH-HX2YJ-W4M2C-33MFC-6HM4Z
http://go.microsoft.com/fwlink/?LinkId=532540&mstoken=F2H9C-PCMJ4-MQ93V-WY79K-7TWXZ
http://go.microsoft.com/fwlink/?LinkId=532540&mstoken=Y47RJ-6MCMJ-9FT2G-YY9QF-HTD6Z
http://go.microsoft.com/fwlink/?LinkId=532540&mstoken=WY2H4-T2D9V-R347G-M2F7T-HVJPZ
http://go.microsoft.com/fwlink/?LinkId=532540&mstoken=9WVFG-C9K9C-JQMH2-GK6VW-YXY6Z
Each will only work once, so please don't use it if you don't already have a Hololens. I look forward to feedback!
You can also see a demo video here: https://www.youtube.com/watch?v=y8LD5F-bDGk
    Hey, thanks for this! What do you think of adding a full-screen mode so the app bar can be hidden? The tricky thing would be figuring out some UI to bring it back. As I understand it Gaze triggers hover events, maybe an invisible hot corner of some reasonable size? Something you'd dwell on for 3 seconds or so. Or there's always voice input.
    https://msdn.microsoft.com/en-us/library/windows/apps/windows.ui.viewmanagement.applicationview.preferredlaunchwindowingmode?cs-save-lang=1&cs-lang=csharp#code-snippet-1
    Actually, a quick test on the emulator seems to show the app bar flashing back briefly when I air tap outside the bounds of a fullscreen mode 2D window. If I line up the gaze cursor above the window where the adjust button would be, I can snag it pretty easily. Not sure if this is by design, but might as well exploit it for now...
    Is it able to run multiple windows concurrently?
    @Dvashgadol by my testing, no; a second instance puts the first to sleep. @Daeken do you have plans to support multiple active windows?
    This looks awesome. I'm purchasing as soon as I reset this Hololens to my account. This is one of the #1 hololens use cases for me.
    This app doesn't work, when try to connect vnc server, it just goes sleeping status.
    seems some issue with rs4 release
