HoloLens Emulator install error
After download to D drive, and install to separate path , but can not choose path,
and install error
http://go.microsoft.com/fwlink/?LinkID=724053
Property(S): DATABASE = C:\WINDOWS\Installer\984ab1.msi
Property(S): OriginalDatabase = C:\ProgramData\Package Cache{914A5C4B-0149-471A-9423-D29BB0A41864}v10.1.11082.1039\Installers\Xde.msi
Property(S): UILevel = 2
Property(S): MsiUISourceResOnly = 1
Property(S): ACTION = INSTALL
Property(S): ROOTDRIVE = \
Property(S): CostingComplete = 1
Property(S): OutOfDiskSpace = 0
Property(S): OutOfNoRbDiskSpace = 0
Property(S): PrimaryVolumeSpaceAvailable = 0
Property(S): PrimaryVolumeSpaceRequired = 0
Property(S): PrimaryVolumeSpaceRemaining = 0
Property(S): INSTALLLEVEL = 1
Property(S): SOURCEDIR = C:\ProgramData\Package Cache{914A5C4B-0149-471A-9423-D29BB0A41864}v10.1.11082.1039\Installers\
Property(S): SourcedirProduct = {914A5C4B-0149-471A-9423-D29BB0A41864}
Property(S): ProductToBeRegistered = 1
MSI (s) (64:98) [16:08:28:814]: Note: 1: 1708
MSI (s) (64:98) [16:08:28:814]: Note: 1: 2205 2: 3: Error
MSI (s) (64:98) [16:08:28:814]: Note: 1: 2228 2: 3: Error 4: SELECT Message
FROM Error
WHERE Error
= 1708
FROM Error
WHERE Error
= 1709
MSI (s) (64:98) [16:08:28:814]: Product: Microsoft Emulator 10.0.11082.0 -- Installation failed.
MSI (s) (64:98) [16:08:28:814]: Windows Installer 已安裝該產品。產品名稱: Microsoft Emulator 10.0.11082.0。產品版本: 10.1.11082.1039。產品語言: 1033。製造商: Microsoft Corporation。安裝成功或錯誤狀態: 1603。
MSI (s) (64:98) [16:08:28:850]: Deferring clean up of packages/files, if any exist
MSI (s) (64:98) [16:08:28:850]: MainEngineThread is returning 1603
MSI (s) (64:64) [16:08:28:854]: RESTART MANAGER: Session closed.
MSI (s) (64:64) [16:08:28:854]: No System Restore sequence number for this installation.
=== Logging stopped: 1/4/2016 16:08:28 ===
MSI (s) (64:64) [16:08:28:870]: User policy value 'DisableRollback' is 0
MSI (s) (64:64) [16:08:28:870]: Machine policy value 'DisableRollback' is 0
MSI (s) (64:64) [16:08:28:870]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (s) (64:64) [16:08:28:870]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
MSI (s) (64:64) [16:08:28:870]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI (s) (64:64) [16:08:28:874]: Destroying RemoteAPI object.
MSI (s) (64:84) [16:08:28:874]: Custom Action Manager thread ending.
MSI (c) (C4:8C) [16:08:28:874]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI (c) (C4:8C) [16:08:28:878]: MainEngineThread is returning 1603
=== Verbose logging stopped: 1/4/2016 16:08:28 ===
Windows 10 Pro and above is supported, not sure about regions yet.
Dwight Goins
http://dgoins.wordpress.com5
emulator installs into your local appdata directory, im not really sure you can change it. 2. the error suggests you have a lock on something the installer needs to finish installing, which could be security related. not enough permissions maybe? or read only location?
try running install as admin.
Dwight Goins
Actually i had run as administrator, but still have install error
Here is the video i install emulator
https://drive.google.com/file/d/0Bxs_ao6uuBDUY2RNLU56RkJjV2M/view?usp=sharing
I wonder if it's a region + culture encoding issue in the installer or packaging. Do you have another system to install it on which has the English-US "en-US" region and culture language pack install of Windows 10?
Also are you on at least windows 10 Pro and above?
Dwight Goins
I am using window 10 home edition in Hong Kong region, do it support?
i succeed to install now
Dwight Goins
What are some of the steps you took to install the emulator?
I am from India and I run windows 10 Home. I too have the same problem. Please help me.
I too, cannot install the emulator. It worked on one system, but on this one, I get "This app can't run on your PC". When I run as admin from CMD prompt and close the error message, it returns "Access is denied". Both systems are Windows 10 Pro 64-bit 1511 with all updates. Working one is an intel, non-working is AMD. Both have virtualization on and have Hyper-V installed
Figured it out. It cannot be installed from a USB 3.0 stick for some reason. I coppied it to a local disk, and it installed fine.
