Locatable Camera known issue? (PhotoCapture.CreateAsync doesn't start)
Debug.Log("Initialized");
PhotoCapture.CreateAsync(false, ( a ) => { Debug.Log("Started"); });
I get Initialized, but never Started. Webcam capabilities are on in both Unity and explicitly in the appxmanifest.
HoloSheep mod
@JimGale I copied and pasted your two lines into one off my object's start methods with only minor modification of the strings to ("PhotoCapture Initialized" and "PhotoCapture Started"). Doubled checked that I had the Webcam capability checked in Unity's player settings, publishing settings.
I added the necessary using statement:
and then ran my project (with debugging) first against the emulator and then on a device.
In both cases both the Initialized and Started log statements executed and output to my immediate window. In the emulator there was another statement that said something about the webcam not being available (as you would expect).
thanks, after updating to the latest HoloOS, I also updated Unity, Metro-overlay, reset and re-paired. Now it works.
If anyone still has this issue, I found that I required the 'microphone' capability. I could consistently cause and eliminate the issue by toggling it the capability in the manifest.
That fixed it for me as well. Thanks @NickDarvey
Does anyone know how to fix the following error:
https://drive.google.com/file/d/0B9_mLRD-3A03X09MWDVEMF9qUmM/view
"Unable to find plugins folder WSAPlayer. Native VR plugins will not be loaded."
You are using x64 Unity and HoloLens is an x86 system therefor any WSAPlayer plugins needed to be in x86 folder and Native x64 plugins are no use for HoloLens, hence they not loaded
I copied the Unity files (including WSAPLayer) to the x86 folder, but the error persists. Any suggestions?
In Unity Select Inspector and click on the plugin. In Inspector make sure only WSA is selected and Windows store is selected.
See if there is an error box at the bottom of page, check the characteristics of the DLL to see if its supported by Unity.
