Cursor don't recognize FBX file why?
Memo
Hello everyody,
If i create an object in unity then the cursor recognize my object. But if i import my file from Autodesk Maya (fbx file) my cursor can't recognize the imported object. Any ideas?
dvroegop ✭
Do you have a collider on your object? By default it may not have one...
Dennis Vroegop
Emerging Experiences MVP5
Dennis Vroegop
Hi @dvroegop yes collider was on but it don't work.
@dvroegop yeah you're right i used the wrong collider
thanks
