Usage with the PC?
Hey HoloLens community,
Im not quite sure if this is the right section, but I just want to suggest it to the team/developers.
Would it be possible to develop an App which connects the HL to a PC for simulating monitors? Normally you buy a monitor, connect it to your PC and then you can use it f.e. for surfing, while you have a video opened on the main monitor. It would be absolutely awesome if the HL detects a PC which is connected with the HL is turned on and then asking the user if it should display some virtual monitors. The advantage to normal, physical monitors would be that they aren't size limited and not bound to the location where they stand. With the HL you could place them anywhere you want, but still control them via mouse and keyboard. Also useful would be to mark objects (Lamps, etc.) which are infront of the user and would normally cover a small part of the monitor, so the HL places them behind these objects. But thats not too important, it would just make the whole thing more comfortable. Because I'm a beginner at developing and certainly not a team of skilled developers which could realize this, I'm posting it here. It would be absolutely awesome if you give it a try. If I can help in any way, feel free to ask ^^
Thanks for spending your time,
Felix
Hi @m1212e ,
Yes you can potentially do this with Holographic Remoting.
An example with it in Unity is here, and a futuristic vision of it with devices like Occulus Rift and Intel's Untethered VR device is here.
Dwight Goins
http://dgoins.wordpress.com
Future Vision is here
Dwight Goins
