Aligning offline Unity coordinates with SRMesh.obj's coordinates
Holograms 230 gives an example where you can load a saved SRMesh.obj (saved via the device portal) into the Object Surface Observer script and show the HoloLens mesh inside Unity on the computer (i.e., not on HoloLens). I'd like to be able to save exactly where the user wearing the HoloLens looked in the room and later load that into Unity on the computer (i.e., not on the HoloLens). I tried doing this, but unfortunately the HoloLens camera pose always starts at position zero and the identity rotation (no matter how the HoloLens is positioned and oriented with respect to the mesh that was saved to be SRMesh.obj). In other words, when I load SRMesh.obj in Unity on the computer and try to add certain saved camera poses (e.g., via saving Camera.main.transform while running HoloLens), those camera poses are not aligned correctly to SRMesh.obj.
I have 3 ideas on how to fix this:
1. Use spatial anchors / world anchors. But would this work in Unity on the desktop computer?
2. Use the most recent HoloToolkit that apparently has some remote mesh capabilities (has anyone tried this?), and hopefully I could save the remote mesh with the right coordinate system...
3. Save the camera poses and the mesh while running on HoloLens, in hopes of this saved mesh being in the correct coordinates.
Does anyone know what the correct solution is to this problem?
I just tried solution #2 above and it works!
Holoben, can you explain how did you do it? thanks
@comodin Please look at the instructions on the HoloToolkit page: https://github.com/Microsoft/HoloToolkit-Unity/blob/master/Assets/HoloToolkit/SpatialMapping/README.md. If that doesn't help, then you can message me.
I'm really appreciate the info @holoben!
I'll do my test as soon as possible!
I'm really appreciate the info too @holoben Thanks !
