Server client between PC and hololens
I want to send image data from hololens to a PC / server for image processing, and then send the data back to the hololens. I'm not sure which networking libraries are best to use for this. Any suggestions would be very helpful.
Thanks in advance.
you could use an HTTP server or REST API or ASP.NET or anything really on the PC/server.
Which libraries would you use for the hololens side of networking? The holotoolkit is not so well documented, and I'm not sure if the Unity Networking will work for this?
