Holographic Remoting app problem!
I'm using Unity 5.5.0b7(32 bit) with Holographic Remoting app running in HL. I connect to HL correctly but I just see my holograms for a second and then disappears .
I still have connections with Unity because when I move my head, I move the Scene into Unity.
I disable any Firewalls on machine and I tested in differents Wifi’s network.
But, the most strange thing is when I try to record a video to show you what’s happened.
... with HL all objects disappear in few second but in the video you still can see the left object, but not all of them. I think I need a restart myself ;-=))
My objects are simple cube primitive.
I can stop in Unity but then Unity is block. Any Idea what's I'm doing wrong-?
Optionscomodin ✭
After to run different versions I resolve my problem formatting my laptop
Thanks5
Others have also reported similar remoting issues on b7. Try using Unity 5.5.0b6 for now.
Thanks @vdandi but same issue in Unity 5.5.0b6
+1
same problem here
Is the reason of this problem maybe related to low computation power of the host laptop/PC?
PS: using 5.5.0b7
Thanks
