How to read parameters of Hololens sharing NetworkInMessage?
I build a small application. In that implemented sharing working fine. I trying to pass a value using NetworkOutMessage and reading a value using NetworkInMessage not getting the value (string,int).
Below code is to send a message:
// If we are connected to a session, broadcast our head info if (this.serverConnection != null && this.serverConnection.IsConnected()) { // Create an outgoing network message to contain all the info we want to send NetworkOutMessage msg = CreateMessage((byte)TestMessageID.HideMenu); msg.Write("SomeMessages.."); // Send the message as a broadcast, which will cause the server to forward it to all other users in the session. this.serverConnection.Broadcast( msg, MessagePriority.Immediate, MessageReliability.ReliableOrdered, MessageChannel.Avatar); }
Below code is to receive a message:
void UpdateHideMenu(NetworkInMessage msg) { long userID = msg.ReadInt64(); //getting value var message = msg.ReadString(); //not getting string value }
Please someone help me how to pass some value from sender to receiver using sharing prefab.
its working fine. Ignore this.
